Old 04-01-2005, 03:01 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
David,
I see all these people talking about the new TKO600. But, the gear spreads (2.87 first) are really similar to, just a touch wider, than a wide ratio toploader (2.78 first), but with an overdrive.
I'm not a racer, no experience other than Run-n-gun. I have a wide ratio TL with a 3.07 rear, and I think the wide ratio TL is just a little too wide. I'm seriously considering changing to a true close ratio tranny , either a CR toploader (maybe one of Kee's aluminum versions), or a custom CR jerico/G-force 5 speed, keeping the 3.07 rear in either case.
I just think the WR toploader gears are spread alittle too wide, and you're really not gaining anything with the TKO600, except for an overdrive, which you really don't need , as to gear the cobra correctly with first gear (2.87), you will need to run sometyhing like a 2.88 or 3.07 rear otherwise first gear is geared too low, and then you probably don't need overdrive with those rear ratio's.
To each his own.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
