Old 04-01-2005, 08:28 PM
DuckRyder's Avatar
DuckRyder DuckRyder is offline
Cobra Make, Engine: I Wish, Just an old truck with an FE
Send a message via AIM to DuckRyder
Default Re: Distributor Shaft hole in the block
Originally posted by musclecargt500
The hole in the block is larger than the ring. With a brown and sharpe caliper the ring outside diameter measures .510". It will fall through the hole in the block. Is my block shot or what? The distributor shaft is supposed to be snug in this hole (my understanding). I didn't have the distributor for testing but the shaft on the distributor is much less than .500". My friend told me the hole in the block should be ~7/16". Please tell me I am missing something here. WHY WOULD ANYONE DRILL THIS BIGGER? Keith Craft, are you out there? Ever seen such a thing?
Sounds like it might be an FT block, these have a larger hole. Federal Mogul makes a bushing for it.
ARP's main cap bolts will clear the oil pan (barely) if you are running a CJ windage tray and the two gaskets. If you are concerned about the stock bolts.
Your build is going about like mine, remind me to go on my ATI Balencer rant when its all said and done.
Robert
1972 Ford F100 Ranger XLT
1975 Porsche 914/4 2.0
2002 Honda RC51
323i.net
RangerXLT.com
The Forums@323i.net
