Old 04-03-2005, 09:37 AM
DAVID GAGNARD's Avatar
Ron;
Thanks for the info,I do have a relay for the electric fan and have the same set-up in my street 65 Fastback........... I was/am planning to fuse each switch seperately,just needed to know how to do it,I guess putting the fuse before the switch also would help prevent from burning out the switch..........right now I will have only the MSD box on the ignition switch and one acces. switch will go to the relay for the electric fan..........I'm running a mechanical fuel pump and have no other electrical things to wire up,trying to keep this as simple as possible.............
I'm going to "split" the hot coming in to the switch panel and fuse each of the two leads before the switches with an in-line fuse,any recomendations for the fuse itself for the MSD box and a 17" diameter fan????? Not sure of the MSD recomendation,but I could check with the fan maker to see what they recomend as the proper size fuse........
Thanks again and do not be surprised if you get a call in a week or two when the battery gets hooked up,hopefully NO smoke or blown fuses!!!!!!!!!!!!!!!!!!
David
DAVID GAGNARD
