Old 04-04-2005, 05:15 PM
SFfiredog Mike the Jackson boys have all the odd ball parts you are talking about. For the block cam bearing, they tap and plug the holes in the block and modifly the oiling system. Back plate, front plate, gears, chains, tensioners, chain guides, all avaliable. I know about the heads, they come with the bearings. Billet cams also. The intake may be the only hard part to get depending on 4 barrel, 2 4 barrels, or webers. I know where a set of valve covers are, ingood shape. Have to find out if they are the low clearance or high clearance for the valve train. Pointer you can make yourself. What's the height differents between a hemi and a sohc. I know that the sohc has longer valves. Timing covers I have seen at swap meets. Everything maynot be brand new but close enough. Tell me when you are going to be around, we'll talk. Rick Lake Ps this is why I have a list of parts people and what they sell. Builder also, mostly guys in there 60's with machine knowledge. Like yourself, your in the book
