Thread: Brazing metal
Old 04-06-2005, 03:06 PM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Default Brazing metal
Hi,
I need to braze two pieces of aluminum together for a car related enhancement. The problem is I can't braze it in place so it has to be done off the car.
Since the two parts are odd ball shapes and angles, I can't clamp them well.
Any ideas as to how I can hold them in place while I braze them.
By the way the pieces of aluminum are 1/8 in thick and vary in width from 1/2 inch to an inch.
Can you use clay? I tried molding crumpled-up tin foil to the two pieces with some success but the pieces still move a bit.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
