Old 04-07-2005, 07:20 PM
NASSTY NASSTY is offline
Cobra Make, Engine: RCM, 4 wheels, two doors
I should've also added that I'm not using trailing arms in my cobra because of the 10mm tube. Most trailing arms probably would be set up with some sort of rubber mounts to allow for some movement in order to stop the suspension from binding up as it's very difficult to mount the trailing correctly with the right geometry. This is the case with other RCM's that I've seen. The only way I think I could do it is to mount them from behind instead of trailing but this would require some mods to the chassis which I doubt the engineer would like. My engineer has no problem with my RCM not using trailing arms.
