Old 04-08-2005, 10:30 AM
To many variables to be "sure" of what length pushrod to use!
Has the block been "milled" (decked) so it is not as tall as it used to be? You need to verify deck height is standard first thing. "Probably" the heads are standard thickness and both the same thickness, being new ones?
I guess you could "assume" the head rocker arm shaft mounting pads are standard height, and the rocker stands have not been milled down (mine were)!
I would do a "dry assembly" by mounting at least one head (with gasket) to the block, cam and lifter and check with an "adjustable push rod" to determine correct length.
George (Gessford) sent me an adjustable pushrod checker to use, but you can buy them fairly reasonable. I then ordered my push rods through him. Determine length and order "custom" push rods. I wonder if in fact the 9.370 IS a "custom" size all ready?
