Old 04-13-2005, 07:08 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Better late than never.....
I assume you're talking about the reverse gear engagement T handle, which on mine is non-functional but there for the original look.
I can take mine apart as follows:
1 - unscrew the ball off the top
2 - there's a pin down inside the shaft that sticks through the T-bar to keep if from sliding out the sides
3 - Use a magnet retriever, or just give the t-bar a sharp pop upward and watch out for the pin to fly out the top of the shaft
4 - slide the t-bar out sideways
5 - put on the boot and reverse to re-assemble
