Old 04-14-2005, 06:30 AM
StanJ StanJ is offline
Default Sorry for taking so long...
Curt, here as a couple of pics showing the PV baffle and how it is installed. In oval-track applications such as this one, we orient the baffle with the fuel entry hole slightly toward the passenger side (the metering block pictured below is a primary)...which is where most of the fuel in the float bowl will be as the car exits the turn (for road racing applications we install them with the fuel entry hole facing straight down). We sell a pair of these (including new bowl and metering block gaskets) for $18.00 U.S. As you can see though, this is not a complicated piece to make...well within the capabilities of almost any machinist. If you have a lathe and some .625" diameter 6061 bar stock lying around, feel free to build your own with my blessing.
When I took these pictures, I didn't realize that we were out of stock on the modified float bowls; should have some finished up by the end of the current week.
Stan Justus
Stallion Racing Components
1704 Dallas Lake Rd.
Soddy Daisy, TN 37379
(423) 847-0441
(423) 847-0461 fax
