Wiring harness
For those guys who have done or are doing there own wiring harness, where did you source your terminals from?
I am not going to use indivdual bullet or spade terminals at each connection and want to buy 2, 3 4 etc pind connector blocks, where can I find them?
I have some large 15 - 20 terminal connectors for passing through firewall and rear bulkhead but cant find a source for smaller connectors.
On the same subject, I realise that most of the wire harness kits are probably from the states, do you have to modify in any way since we use indictaor light instead of flashing brake light?
And do the harness's normally have an earth return built into the light systems?
Cruising in 5th
