Old 04-17-2005, 08:49 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Bob:
My sentiments also. The seat attachment is designed to hold the seat in place only. The retention comes from the belts and if you break them or the mounting points the last thing you're going to have to worry about is the seat retention. The belts and mounting points are in the 5,000 lb tensile strength range. That's enough to strain you through the belts before they break.
DonC
