Old 04-18-2005, 07:09 AM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
The easy way to tell if you do not have enough volume is the car will tend to die out with a long blast on the gas. If the pump can not keep up the engine will fade away as it starves for fuel.
I do not think you will have a problem with that. Check your GPH rate as listed for the pump you are using.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
