Old 04-26-2005, 01:52 PM
rms427 rms427 is offline
Club Cobra Member
Original Shelby Owner
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
Default Help - Rear Suspension Adjustment
I need to adjust the toe in/out on the rear suspension. The car has the original 427 suspension except for Konis. Is there a way to do this without taking the suspension apart? There are two nuts on either side of the a arm (where it attaches to the frame) that allow adjustment. Unfortunately it looks like I need to take everything apart to get to the nuts. What's the least amount I need to take apart to adjust it?
The reason I need to do this is I screwed up when I redid the rear suspension and changed the setting on one side and now have high wear on that tire. I assume if I go back to where it was I will be OK.
Thanks, Ray
