Old 04-26-2005, 03:53 PM
rms427 rms427 is offline
Club Cobra Member
Original Shelby Owner
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
I think I need to adjust where the a arm attaches to the frame. The a arm attachment to the frame fits on a threaded shaft with a nut on each side that allows it to be moved forward or back. I need to move the a arm attachment forward. The shock and spring are in the way to get a wrench on the adusting nuts. I know if I take everything apart it is easy to adjust but it's a lot of work getting to that point. Maybe I need a special thin wrench to adjust the nuts or maybe I can just take off the spring and shock assembly. I just don't want to take apart anything more than I have to.
If I can adjust the toe by the trailing link then I agree that would be easy. But I assume that the attachment point for tha a arm has more effect than the trailing link and that's what I changed when I put the suspension back together.
Thanks, Ray
