Old 05-02-2005, 07:08 AM
69 Mach I's Avatar
69 Mach I 69 Mach I is offline
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
Originally posted by xlr8or
Perhaps the distributor curve has changed significantly on MSD unit from what it was. Is the base timing the same? Is total advance coming in at the same RPM and same amount? Maybe your not getting enough total advance and that is why it starts dropping off at 5400.
Good point. I don't know whether the base timing changed or not. As for the total advance, there are these springs you install inside the distributor. I might have selected the wrong ones when I installed the new distrib.
