Old 05-04-2005, 10:42 AM
Mike Simard Mike Simard is offline
Cobra Make, Engine: Porsche 928 S4
Can you verify that you have coolant flowing through the block and heads? It might be possible to put a head gasket on the wrong way, the coolant flows through a passage at the end of the block and the gasket must have the corresponding hole there.
If you find water or steam inside the valve covers you may have a head bolt leaking, the threaded holes go right into the coolant so you must use a thread sealant.
Good luck!
