Old 05-04-2005, 05:13 PM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
Question Diameter of Stock Pulleys ???
I'm trying to find out what the diameters are for stock pulleys for the water pump,crank and alternator.This is for a 351w,that is now a 418w.
Looking to figure out how much the factory overdrove the water pump and alternator.
While I had the 392w cooling was never a concern with the March performance pulleys.The Spal 16" fan and Griffin 2 row,1.25" tubes radiator did a fine job.
The radiator is rated for up to 600 hp.
I now have a 602 hp 418w and in slow traffic in 80's degree the water tempts go to 200 - 210*.
I have completely gone thru the cooling system and all is operating as they should.
I called Griffin and told the tech people the story. The first question they asked is "Are you running March pulleys ?".
They said that March performance pulleys were the #1 cause of low speed cooling problems when the radiator capacity is being pushed a little.
March perf. pulleys underdrive the pump 12 %.
I have ordered their Street Rod water pump pulley.It will overdrive the pump 5 % .
Any help with the diameters of stock pulleys would be appreciated.
