Old 05-04-2005, 05:17 PM
SVMCOBRA SVMCOBRA is offline
Need more info on your 302. Is it carb or FI? Did you check to make sure the fan is running in the right direction? Did you have time to set the timming? Do you have the correct rotation water pump? If you are running a carb I say yes you need a PVC or at least some valve cover breathers. I would also double check to be sure your heads are torqued correctly.
