Old 05-05-2005, 10:10 PM
joea's Avatar
joea joea is offline
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Been there...done that. If you are using hydraulic lifters then I agree with Bob....you have valve float. Cure? Heavier valve springs. When you remove your rocker assembly look for a star pattern on the top of the stem. This would indicate valve float. A circle pattern would be the correct pattern without float.
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
