Old 05-07-2005, 01:41 AM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Mike it is the high pressure relief valve in the rear of the oil galley.
It blows off oil back into the pan when the oil pressure gets to high. I don't have a picture handy. I not sure but your service block should of had it too. There should bee a couple of allen plugs where they Machined the oil passeges from the rear to the front of the block. There's three around the cam plug and the two down the leftside. This is just from memory so you might want to check out some other resource or maybe someone can post a photo hear.
Tony
