Old 05-08-2005, 01:34 AM
AmericanPie AmericanPie is offline
Cobra Make, Engine: To be determined
Originally posted by FUNFER2
I agree with the solids. I've had no problems with mine. 600 lift-252 duration. Roller Earson rockers. Adjusting the valves take's less than a hour, from removing the valve covers, adjusting the valves & buttoning it all up again. Things like, using all studs, rubber gaskets & the valve lash tools, help in a faster job. After the engine build, I lashed them twice. Since then, only twice per year. With a flat tappet, you can hear & feel when they get loose. I'm happy with my set-up anyway.
Kevin,
Can you give me some more info on your cam? Brand? Part #? It sounds like a nice hot street grind.
