Old 05-08-2005, 05:42 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Holley 4150-9379 and ProForm body and plate for sale
Just installed a new Demon 750 so the old carb is for sale:
Holley 4150, model 9379
750 cfm
Double pumper
Center hung floats
Annular flow venturis
4 corner idle mix screws
Metering blocks on primary and secondaries
No choke
I have replaced the main body with a ProForm main body and ProForm billet aluminum throttle plate. The ProForm unit has:
- replaceable screw in air bleeds
- Adjustable secondary idle speed screw
- No choke horn
- PV blow out prevention
The original main body and throttle plate will be included - nothing wrong with them as far as I know. Or, will sell the ProForm body and throttle plate separately, and sell the Holley 9379 in original form.
Installed 50cc accelerator pumps on both primary and secondary side
4.5 Power Valve on primary, no PV on secondary
Nitrophyl floats
#73 jets on primaries, #80 on secondaries
#40 shooters on accelerator pumps
Blue Holley removable gaskets
Clear site plugs
Just rebuilt - less than 100 miles
Will change jets and accel pump shooters to suite your request, and can provide the 30cc accel pumps and 6.5 Power Valve if you prefer that.
The Holley 4150-9379 retails for $446 at Summit
The ProForm main body retails for $100
The ProForm throttle plate retails for $130
Please post or email if you are interested and make me a respectable offer.
Thanks!
Scott
