Thread: Jag IRS
Old 05-09-2005, 06:48 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
Yo Scott,
From the answer I gave ya a couple days ago:
Is the hub bad?
If it's the studs they are screw-in for the stock Jag hubs. The thread is the same as the outer portion - 1/2-20 if memory (?) serves. You need to grind or chisel off the staked-over area on the inner or differential side and unscrew them.
New studs are (fairly) readily available as they fit a whole bunch of years.
The hard part is re-staking the inner ends after the new studs are screwed in. Takes a pretty big press or hammer
Tom
