Old 05-09-2005, 09:07 AM
tony martin tony martin is offline
Send a message via AIM to tony martin
Default WA
GUYS,
2 EASY WAYS TO ADJ. FRONT END CAMBER.
1. SLOT THE HOLES IN THE UPPER STRUTS.
THIS IS SIMPLE AND IF U USE GOOD QUALITY,LARGER OUTER DIAM. WASHERS(2-3MM THICK)AND TIGHTEN THEM PROPERLY THEY WILL NOT MOVE.
2. U CAN REPLACE THE BOLT WHICH HOLDS THE STEERING KNUCKLE TO THE STRUT WITH AN EXCENTRIC ONE.
TSW (TIGER WHEELS) SHOULD BE ABLE TO SUPPLY.
IF U CANNOT FIND THEM LET ME KNOW AND I WILL SOURCE THEM OUT HERE OR MAKE THEM FOR U.
DO YOUR HOMEWORK AND CHECK TIRE WEAR BEFORE U CHANGE ANYTHING,REMEMBER THINK TWICE AND CUT ONCE!!!
TAKE CARE,
mr lucky
