Old 05-10-2005, 08:39 AM
S_Beaudry's Avatar
S_Beaudry S_Beaudry is offline
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default Need serious help . . . Cylinder # 3 taking on water!
Carrying on from my last post, I pulled all spark plugs and checked them, all were dry and clean except for cylinder #3.
The plug was pretty well wet so I took a long screwdriver, taped up the end real good, and put her in and spun her around cylinder # 3, she came out "dripping" wet!
So, my coolant pressure problem is found, leaking into #3 right?
Please look at the pics attached and give me some advice here as to why coolant is getting into the cylinder.
Is it just the head gasket or maybe a bad block?
What the heak is all the gook on the top of block and the bottom of the head gasket?
What is the small crack-like circle in the block in the bottom right corner of the second picture here? There is also one of these on the top of the block between #3 & 4.
Is it leaking due to all that stuff caked on the block and head?
Please help.........
I'm not busy because I did it right the third time . . .I think!
