Old 05-10-2005, 10:16 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
How safe do you want to be?
It does not look like you broke anything, so you could risk it and say, "leaking head gasket" or you could pull the engine and rebuild from the ground up, testing the block for cracks before you assemble it.
It is a matter of budget and time. I think you should be able to get an overhaul gasket set ( without bearings ) around $150.00.
Testing may cost you up to $200.00, but if I found this I would be suspect. I might want to rebuild and make sure.
Just a thought.
