Old 05-10-2005, 10:44 PM
69 Mach I's Avatar
69 Mach I 69 Mach I is offline
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
Default Re: Harmonic balancer
Originally posted by JohnB
I have a engine vibration at 2000 rpm and again at around 3000 rpm, might be there at higher rpms but really only notice it when warming up. This car used to have an air condition compressor but the controls at the dash were never installed so I removed it. Would the ballancer be affected by the AC compressor ie. new one needed since removal ? And does it sound like the ballancer. Vibration is not bad and can't be felt while driving. I had an old pickup with the wrong ballancer and it was very noticable until changed by a mechanic.
I doubt it would be caused by the elimination of the AC compressor. You give the rpm range but does it appear at a certain speed and then go away? In that case, it could be a balance problem such as a tire out of round or an unbalanced wheel or even brake rotor. If this is happening you need to find an experienced alignment shop and you may need to balance the wheel while it is on the car. If your problem does not manifest itself at a certain speed and then go away, then you need to look at engine related things.
