Old 05-11-2005, 09:50 AM
S_Beaudry's Avatar
S_Beaudry S_Beaudry is offline
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default Head Bolt Torque
Putting the 302ci back together, so I need to know.......
Need the correct torque for the upper and lower (the same?) headbolts?
Also, do they need to be step up in torqueing, start at 60lbs and then another round to 70lbs?
They are iron heads, believe they are '87, and the block is a '74....
Much appreciate the help......
I'm not busy because I did it right the third time . . .I think!
