Old 05-14-2005, 04:02 AM
CSX4815 Mike Go for it You have to deciede what size throttle bodys you are going with? How big is the motor? What is your max rpm level? 48,50,52,58 mm I am going with a 489 or 496 motor and will use the 58mm. I have a F.A.S.T ecu allready in the car from my throttle body setup. Works great. You know you will need 40-50 psi electric fuel pump, 2 lines for gas, 1 supply,1 return, hooking up sensors. It works better than any carb. You will not get max power out of it at high RPM compared to a carb. You will need a large battery and good charging system, 80 amp min with all the electric on and running. Good luck Rick Lake
