Old 05-14-2005, 11:31 AM
blykins blykins is offline
A small block C6 should work fine. The only thing I can think of is that the flexplate you have is for a C6....I was looking through the Jegs catalog and they offer different flexplates for a C4 and a C6. Apparently your rotating assembly was balanced with this flexplate...
If this is the case, you can remove this flexplate, buy a C4 flexplate and have the one balanced to match the other.
How much hp is your engine putting out? That would dictate how stout the tranny needs to be.....and your cam specs and rearend ratio dictates what stall you should use on the torque converter.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
