Old 05-14-2005, 07:23 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Rick, if you sent the e-mail thru CC I never recieved it. Try here: hc38t@msn.com.
Trularin, I know the head tightening sequence on the sb, but thanks for your concern. Liquid teflon? ARP or GM any part numbers? Where I live the nearest and best speed shop is 60 miles away, a good 3-4 hr RT depending on traffic. There is a GM dealer about 20 minutes away though.
I had a valve retainer fail and bent the intake valve on #3. pulled the top end last weekend. Today we pulled the engine. Tore it down, thankfully there was no damage to the lower end. We are going to replace the #3 rod bearings. Install a new cam, new aluminum heads, Edlebrock RPM Performers, timing chain. I'm not after super hipo and I know there are other heads and cams out there but for the $ this works for me.
I'm going to be using the 1011-2 gaskets, recommended by Edlebrock tech support.
Thanks
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
