  #70 (permalink)
Old 05-17-2005, 05:54 PM
Three Peaks Three Peaks is offline
Alex, it looks great. What program did you use to design the geometry check the bump steer? Are those the Pole Position pieces that you modified?
Are you using the original pick up points or did you redesign the mount points for your design?
Are those the Mustang II spindles? IMCA style or standard? Whose rotors are you using?
BTW, your workshop is WAAAAYYYYYY too clean! Love the rocking chair in the back ground. I keep thinking that is where you sit and think about the next step- when you're not on the computer in the background. - Bob
