Old 05-18-2005, 03:50 PM
Alex Evonosky Alex Evonosky is offline
Cobra Make, Engine: Building from scratch
Default Thanks for the compliments
Questions answered
Three Peaks: No program to design the geometry, just a lot of reading thinking and racing trial and error.
Yes, Pole Positon (parts are listed further back on this thread).
Mostly original pick up points
Shop too clean.. Usually try to keep things cleaned up somewhat. Makes the project run faster. I did however, just clean and mop.
Mloy: Metal shavings, I had plenty but try to keep ahead of it.
Probably could have bought a steak dinner if I had kept it LOL..
StrictlyPersonal: I would only think you are talking about the tack weld on the upper ball joint plate. That will be final welded along with several pieces on the frame. Plan is to complete the frame, take it off the jig, take it all apart, complete final touch up final welding, clean and pint. Sit in rockingchair, and start putting back together.
I am now concentrating on designing the rear end once I find the quick change I like.
Anyway, that is the plan.
Cobracer#15
