Old 05-19-2005, 10:24 PM
Perf. Eng. Eric Perf. Eng. Eric is offline
Cobra Make, Engine: I drive and test my customers
We have had nothing but trouble with the McLeod. And yes we had pedal stops on the four units that failed! I just installed a Tilton in John Touts. aluminum Superformance Cobra ,and it has been working great. It has no banjo fittings to leak, and it bolts into the bellhousing, not on the candle stick (throw out bearing slide on the front of the trans.) like the McLoud. You can check the operation of the unit before you install the transmission. I will use this type from now on. Call me if you need a part number.(513) 738-5001. Hope this helps.
Eric H.@ Performance Engineering
