Old 05-20-2005, 03:45 AM
cbnus Have you looked into Keisler thrownout bearing? They are at www.keislerauto.com. There is no bleeding needed to be done on this setup. Titlon is the other, You also need to have a pedal stop in your car or you will over extend it and have problems. Make sure that the supply line is bolted down or that will get pulled into the clutch assembly and ripped up. Rick Lake
