Old 05-20-2005, 08:26 AM
slithering slithering is offline
Cobra Make, Engine: Midstates, Genesis 427 S/O
jerry,
I would suggest you install your fuse panel in an area that is as dust free as possible, mine is under the dash. I bought a Dr. K's system but, being an electrician, altered and added to it. His kit comes very easy to install and will perform well, all wiring is of adequate size and is well designed. I placed my battery in the trunk and installed a battery cut off switch behind the passenger seat. I also have a micro switch controlling a relay to energize the starting circuit. If you run into problems repost, we'll help you.
Chris
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
