Old 05-22-2005, 11:10 AM
elgecko's Avatar
elgecko elgecko is offline
Cobra Make, Engine: Scratch build......a little every day.
A concern of mine is if you use the manufactures cam lube(Comp Cams) and are not planning to fire the engine up in a few months, will the lube run off over a period of time, no matter how much lube you put on the lifters and lobes. Is there a thicker cam lube for the extended period before fire-up ????
Cam steel........ Made in China ???
Dave
55 mph is unsafe at any speed. Huh?
