Old 05-23-2005, 01:13 PM
blykins blykins is offline
Default Couple questions for KC (or anyone that knows)
Keith,
Got a couple questions floating around in my head...
1. Are there pistons readily available for the FE in 4.060" size? Different CR's....Different compression heights?
2. The Scat 4.125" stroker crank for the FE.....is it only compatible with BBC rod sizes.....or can you get it to fit standard FE rods?
3. Out of the box, do Edelbrock aluminum FE heads flow as good as some cast iron pieces....better....worse? Say comparing them to a C8AE-H (for example) head with 2.08's and 1.65's and some minor port work done?
Thanks for any advice.....trying to get some info for a future build I have planned.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
