Old 05-23-2005, 05:56 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
see if you can read the tag #'s off the front passenger side of the tranny. If the tranny is original, you'll be able to tell if it's a wide or close ratio. If it's a wide ratio, then change the rear to 3.07 or 2.88's. If it's a close ratio, then I'd probably leave it the way it is.
http://www.davidkeetoploaders.com/idchart1.htm
When you're just cruising on the street, the gears seem spaced too close, bujt when you're racing it, either drag or road racing, they're spaced pretty good, and I wouldn't change it unless you're serious about racing.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
