Old 05-24-2005, 02:49 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Terry, I'm currently running a wide ratio toploader, 2.78 1st, and a 3.07 rear. Runnning the car on the track, the gears are just a tad too wide spaced I think, and I'm tinking on changing to a close ratio TL , 2.32 1st, and keeping the 3.07 rear. I figured that even with the 3.07 rear, I'd still be OK with this set up. 1st gear ratio with this set-up woild be similar to a car with a 3.73 rear, and a tremec tranny starting out in 2nd gear. The 3.07 rear is good for cruising.
I was just trying to find out if it seemed OK witrh this gear set-up / ratio for starting out from a stop, before I made the purchase / change.
Thanks.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
