Old 05-24-2005, 04:50 PM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Anthony:
My TKO w/0.82 fifth and 3.07 rears with 17" rims gives me 22-23 hundred turns @ 70 MPH on my 450CI 428. Good cruising numbers if you're into cruising. Bottom end will still break it loose in 1st and 2nd coming up through the gears if I lean on it.
Depends what you want to do with the car. The 600 ratios are a little far apart for the ultimate in road race gears but doable.
DonC
