Thread: Motor Mounts
Old 05-27-2005, 08:14 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Hey guys my B&B was originally set up for my 302 that I started with however I wanted more. I took my Cobra back to Barry at B&B and he cut my old motor mounts out and installed the new FE motor mounts. SAME LOCATION on the rails the only difference was the the Small Block mounts were actually 1 1/4" taller. I recently switched from a 428 CJ to a 1963 427 centeroiler and had to change those mounts as well because of the older FE engines (pre 1967) only used two bolts on the block where as the later 390, 427 and 428 FE engines use a three bolt to the block configuration.
Good luck with your motor mounts. I hope this helps someone.
Clois
"Let's roll"
"Be part of Something Good
