Old 05-30-2005, 11:37 AM
xlr8or's Avatar
xlr8or xlr8or is offline
Why inadvisable??? If the body is bolted to the chassis and not bonded it should be no problem.
Paul,
Put you car up in the air and measure the chassis to see if it is square. If it is then take measurements to the wheels or ball joints from the frame rails and see if they are the same on both sides. You may find it to be an alignment issue on the car. If everything measures up square then look at removing the body and repositioning it. You might also want to check your wheels. Verify the width and backspacing are the same on each side.
