Old 05-30-2005, 02:39 PM
blykins blykins is offline
Oh, BTW....if you've never rebuilt one before.....when you put it back together, make sure the synchronizer keys are with the right synchro hub.....There is a set that are longer than the other set.....I know this little tid-bit from experience.
Also, since you're going into a rebuild this in-depth, you might wanna order the road race rebuild kit from David Kee. I went that route.....extra beefy bearings, new C-rings, etc.....good kit. Worth the money.
BTW....Ernie...I have the problem that you have.....I'm running a pilot bearing also.....little rough on that last 1/2 inch or so.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
