  #26 (permalink)
Old 05-30-2005, 08:31 PM
mickmate's Avatar
mickmate mickmate is offline
I think looking at the amount of material between the bolt circle and the drum flange hole you would be better taking the material off the drum. If you look at where it will be removed at the back of the adapter I wouldn't want to remove it from there. As you said yourself it is a critical place for strength of that adapter. The drums are cheaper and easier to replace and you will be sometime anyway.
mickmate
http://www.actoncustom.com/
