Old 05-31-2005, 07:58 AM
CobraV8 CobraV8 is offline
Thanks for all the help! I'll try to machine the drums to fit the adaptors, maybe a small radius on the lip is all it takes.
G.R. do you know if there are any part numbers visible on the Granada drums? Using these drums would be the best solution.
Originally posted by Rick Parker
Why are the holes chamfered on the back side???
No idea. The rear adaptors also don't fit the bolt pattern very well. You have to use a hammer to get them over the wheel studs. I tried them also on the front rotors where the front adaptors fit just right: same result.
And yes I did use the holes for the Ford bolt pattern, not the Chev
