Old 06-01-2005, 06:25 AM
2KWIK4U's Avatar
2KWIK4U 2KWIK4U is offline
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
Paul,
As far as the rear, the panhard bar need adjustment to center the rear end under the body. Thats a 5 minute project. May want to check the camber up front. Could only be a simple alignment. It looks like you have the LS comp chassis, and it may be a little difficult to skew the body that much without cutting the floorpans out of the body. Mine fit extremely tight into the frame pans and after I glassed them in place I couldn't move the body if I wanted to. Look in my gallery and theres a pic of my body turned upsided down for coating and you'll see what mean. Good luck.
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
