Old 06-02-2005, 05:21 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default Highly recommend you use the regulator
My Holley electric fuel pump was putting out 14 psi which was 2 x the needed pressure, causing rich running and all kinds of other problems.. it came that way on my "turnkey" and when I rebuilt the engine (a looong story) I wisely added a fuel regulator and trimmed the pressure down to about 7 lbs. That was then, carb, this is now:
I'm changing over to EFI right now and it's going to be a big relief.. I hate carbs, erspecially in a car that can pull 1.1 gs and as a result flooded (overspill) on every hard corner or u-turn I took!
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
