Old 06-02-2005, 09:44 PM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
Originally posted by mr0077
E, go here to David Kee's website and you'll find the info and form you'll need to ID your tranny...
http://www.davidkeetoploaders.com/idchart1.htm
I think it is on a sheet metal tag on the tranny (if not lost in space in the past).
All good advice.
I am trying to recall from memory, but if you ever get the trans out, you can also remove the front bearing retaining collar (the snout) on the front of the trans. Under there, on the shaft, if you see a machine groove then you've got yourself a wide ratio trans.
Regards.
