Old 06-04-2005, 01:50 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Default blue blunder allright !!
I also had a blue thunder manifold which I had to throw away. A hole between the #1 cyl pushrod hole and the water passage was seeping water into the engine. No welding got things straightened out. If you welded here, you got a hole there, if you welded there you got a hole somewhere else, and so on.
The welder said it was a very bad casting. I have an edelbrock now.
Nothing sounds better than a Cobra in a Tunnel !
